how to create a new board in a project
Ayman Ragheb December 27, 2022
Hello professionals,
Appreciate it if to let me know step-by-step of how to create a new board in a project in Jira Work Management.
Nic Brough -Adaptavist-
December 28, 2022
The answers you have had about Jira Software are what you have to do.
Jira Work Management projects have a board built into them and you can not add more directly to the project.
If you want more boards for them, you have to add Jira Software boards that look at the JWM projects.
Sushant Verma
Hi @Ayman Ragheb
You can follow the below document:
https://www.atlassian.com/agile/tutorials/creating-your-agile-board
Sushant Verma
Ayman Ragheb December 28, 2022
Hi Sushant,
Thanks a lot,
But this is related to creating a board in
Jira Software not Jira work management?
My doubt is in
Sushant Verma
Still there is no any info about creating a board in Jira work management
what is the difference between jira work management and Jira software ? and if managining an international marketing team where every member managing some countries with some prokects
which one I should use ?
Sushant Verma
If you are doing development you should choose JSW especially if you intend or think you may in the future want to use agile methodologies. JWM is really targeted for business teams and processes, e.g. HR, Finance, basic project management, etc.
You will have basic (non-configurable) Kanban boards. Works well for To Do - In Progress - Done type efforts. Again I guess the question is how does your team work what do your work clothes look like? It’s worth a try just to start with JWM and see if you can set up projects that meet your needs.
To be clear, the boards for JWM are not really Kanban, they don't have the throughput functionality of Kanban.  Plus you can't use them to accumulate status into columns like Kanban.
JSW comes with everything included in JWM but has a lot more configuration available. If you're hoping to do anything with workflows beyond To Do-In Progress-Done then you'll need JSW. Also, mixing team managed and company managed projects allows you to decide how rigidly you want people to follow the processes that are set up while still allowing flexibility when needed.
That being said, administrating JSW is a fair bit more complicated than JWM, especially for company managed projects. There are a lot of settings and configurations. It is possible to retroactively make changes to all those settings after the projects are up and running but it is significantly easier to get everything set up ahead of time
Also, I found that while the Timeline function in JSW standard is better than nothing, it is near useless for actual project management, it does not provide enough detail into the task breakdown and you can't actually schedule anything with it.
Like • 2 people like this
raj shaswat
Thanks Raj
Also the 2 videos are about Jira Software
But my concern is about Jira Work Management
Do you have article for that ?
raj shaswat
@Ayman Ragheb
my bad, i thought of Jira Software.
you can check below video link.
https://www.youtube.com/watch?v=SmLzzY_0EBM
Ayman Ragheb December 31, 2022
@raj shaswat It's fine dear - thanks for your help
I'm now between 2 options:
1- Using JWM - and there is ONLY ONE board
or
2- To use JIRA Software - and still the filters can't prevent issues from appearing in all boards
December 31, 2022
A board is a view of a selection of issues defined by the filter.
You say "the filters can't prevent issues from appearing in all boards " - yes, that's exactly what the filters are for - showing issues.
FREE
Register today
