how to create a script with "start date" triggers a issue to move statuses when it passes 9 months
Matthew Nico November 25, 2022
I'm trying to figure out how to automate JIRA automation to move a issue from one status to another status when the custom created field is either past 9 months or when it is older than 9 months.
I'm currently trying to use the automation built in configuration of a "Scheduled" script under "All Components" in the project's settings>automation>scheduled
"Start Date" >= "-270d" for the filter under scheduled
How do I write or perform the "IF" statement/control to move a issue that meets the requirement above to another status?
2 accepted
Trudy Claspill
@Matthew Nico
Can you provide an example with dates for each of your stated conditions?
To me those sound like the same thing.
Your operator is incorrect if you want to find issues that are older than 270 days. It needs to be
"Start date" <= -270d
Matthew Nico November 28, 2022
That's exactly what I needed along with the other comment. Thank you!
__ Jimi Wikman
You can just add an action after that.
The schedule will already do the filter, so the action will be done on everything in that filter.
Thank you! I just needed to dive deeper into the GUI.
Like __ Jimi Wikman likes this
__ Jimi Wikman
Happy to help :)
