how to disable jira's automation to add creator as watcher?
Lucas Gagliano October 24, 2024
In only one project i need to disable automatic assigned watcher for the creator of the issue, is it possible?
Marc - Devoteam
October 24, 2024
Hi @Lucas Gagliano
This can't be done.
There is the autowatch global setting to be on or off.
In a users profile a user can overwrite this for the user, this will be also for any created issue in any project global.
