how to disable time tracking when creating an issue?
Ramesha May 12, 2024
Need a assistant to disable time tracking when creating an issue? Here I attached the screenshot also
Mohanraj Thangamuthu
May 12, 2024
Hello, Good day. I believe this field is configured as required. You can remove the time tracking fields from the create issue screen. https://support.atlassian.com/jira-cloud-administration/docs/manage-issue-screens/
Sid Pathirana
May 13, 2024
Hi @Ramesha - your screenshot indicates the 3 fields are mandatory in your configuration as the error is saying a value is required in each of the fields.
So after you remove the fields from the create issue screen, you should also check the Field Configuration for the affected issue type(s) and ensure the Time Tracking field is not set to required (ie. it is not defined as a mandatory field).
