For the purpose of automation, I would like to extract the .jar files from an .obr. How is this done?
If you have myfile.obr for instance,
change the extension .obr to .zip as myfile.zip
and unzip it like any other compressed file.
An OBR is just a zip file. Any zip extractor will be able to handle it, including command-line tools like unzip
