×I am trying to fetch a jql for multiselect field where the values in the mutiselect field has more than one value, how can I achieve this ?
Hi Amzad, You can use 'in' operator similar to the status field from the image.
Example: if your multi select field name is ABC and values are 1,2,3,4 then in the query you need to write the following to fetch the records whose values can be 1 or 3 or 4
ABC in ("1","3","4")
Hope this will be helpful.
Hi Uday,
Thanks for your reply your above solution will help to fetch the issues with any particular values for custum field ABC in (1,2,3) will filter the issues with those values. Here, the values should be 1 or 2 or 3. I want to fetch the issues, which has multiple values more than one value
Yes the same query will work for multiple values as well.
Example: if issue field ABC has multiple values selected like 1,2
ABC in (1,2,3) still works.
This is not what the OP is looking for. He wants to find issues where there is more than one value in a multi-select field. He doesn't know the values, he just wants to find the issues where there is more than one.
ABC in (1,2,3) will find issues where ABC == 1, which is not what he wants.
If you had a field with a very small option list you could do a couple of OR's against all the possible multi-value combinations but that doesn't scale very far at all.
Obviously, I was looking for a solution for this too. I'm thinking the only way to do this is with a script (Scriptrunner?). I can easily write one but I was just looking for something in-built.
Hi @Amzad Khan ,
