browsing my jira about or license info i can not find out if I installed 32 or 64 bit version since i want to upgrade i need it to know which version download
please advice
thanks
@Luis LopezLog in as Jira admin then go to the Jira admin button > System > System info then check Java VM you will see the version i suppose.
Best!
Save your spot
