how to get data from JIRA to be used in Tableau Reports
abhishek singh
May 4, 2016
i want to use data from JIRA environment to be used in my tableau reports , Tableau does not provide any native connector for this so may be I have to Built a web connector for tableau , but I need to know how data is saved inside JIRA and how can we retrieve this data both from server and cloud .
3 votes
Amy Biasella
May 9, 2016
For cloud, there is a plugin that can help: https://marketplace.atlassian.com/plugins/com.kaanha.jira.tableau/cloud/overview
Server is a bit trickier, and you may find some answers on this Tableau forum question (essentially asking the same question):
https://community.tableau.com/ideas/3658
abhishek singh
May 9, 2016
thanks amy
Like # people like this
Navarambh Software - Gmail
July 24, 2019
The add-on is available for all three versions of Jira - Cloud, Server, Data Center.
https://marketplace.atlassian.com/apps/1214641/aio-tableau-connector-for-jira
Please feel free to AIO support at support@aioreports.com in case of any issues.
Regards
AIO Support
Like Ones Marsali likes this
Gabe Kressel April 23, 2021
if you're looking for an automation solution, I can recommend you try the 3rd party app Skyvia. It provides Jira to Tableau integration (https://skyvia.com/data-integration/analyze-jira-with-tableau) with an additional step - loading Jira data to a database or a cloud data warehouse.
I found Skyvia on the Atlassian marketplace.
Bibek Behera
June 24, 2021
Hi Everyone!
For using any third-party connector or using any in-house connector you have to keep in mind the points mentioned in the below article, mainly the authentication and performance part!
https://help.tableau.com/current/server/en-us/datasource_wdc.htm
Yuliia Maidanova -Alpha Serve-
You can try our Tableau Connector for Jira https://marketplace.atlassian.com/apps/1221376/tableau-connector-for-jira?hosting=server&tab=overview
It supports a wide range of Jira data configuration to export any field you wish: Jira tables and fields, including Custom fields, History, Jira Service Desk, Tempo Timesheets, Tempo Planner, Portfolio for Jira, Agile, and others.
Here you can find a detailed installation guide https://www.alphaservesp.com/blog/tableau-connector-for-jira-installation-guide/
I'd be happy to answer any questions you may have)
Michael Q
May 5, 2020
You can also use the JIRA DB (if on premise) as a data source in Tableau.
https://developer.atlassian.com/server/jira/platform/database-schema/
vivek srivastava
July 23, 2020
Hi Micheal,
what is the way to connect JIRA DB with tableau.
Can we really do it some way. please share some approach!
Note: I am not so much into API stuff
Pablo Beltran _Marketplace Expert_
The problem of direct access to Jira DB is that it breaks Jira permissions and no support for JQL.
If those things are important for you then SQL+JQL Driver might be an alternative to connect Jira with Tableau via standard JDBC or web data sources and run SQL compatible with JQL remotely.
Disclaimer: I work at the company selling the app.
Madison Quinn
June 18, 2017
Analyze all of your JIRA data in Tableau, Connect your JIRA Cloud to Tableau.
Web data connector for Tableau lets you import JIRA data into Tableau for report creation.
Supports Agile, Custom Fields and Time Reporting
Supports Agile reporting including Sprints & Epics, Time reporting using worklog data and Custom Fields reporting.
Thanks.
Matt Fishel July 30, 2018
Do you know if this also supports Jira Labels?
JulienFritsch
Yes
July 24, 2019
Regards
AIO Support
Nihar Das
August 27, 2019
Dear AIO Team,
Could you please help me to get the AIO Connector? We have JIRA in the Cloud. Could you please help to connect with Tableau Desktop?
I have tried with the above link. I am not able to get this page.
It will be really helpful if you explain the steps with some Screenshots.
Thanks in advance.
August 27, 2019
Thank you for contacting us. Please email us at support@aioreports.com and we will be happy to work with you get the . connector setup.
