how to get the datetime of resolution or status
Jin Wu
hi There,
I'd like to get the datetime of resolution or status by URL: '/rest/api/3/resolution/10000' or  '/rest/api/3/status/10001', now I could only get value of self, description, iconUrl name and id, How can I get the create datetime? thanks!
July 29, 2024
Hi @Jin Wu
Are you trying to get the resolution date / time for a specific Jira issue?  If so, please try using one of the REST API endpoints to return the issue's fields, passing its key in the URL.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-issueidorkey-get
