Here you have some insights that might help you:
Hope this helps.
Start by defining what you mean by "integrate" - what do you actually want it to do?
Then, you'll be able to work out which one of Ignacio's solutions is best for you.
i want to integrate the clarity with Jira cloud versions & i want to view all the projects & time sheet logged in clarity through Jira & vice versa
Mmm, you're not going to have a lot of fun with that - Clarity timesheets generally don't match with JIRA's time logging unless you have built a complete integration where Clarity is using JIRA issues as references for tasks. If you've got to that level of integration, then you're actually in a place where you should bin Clarity.
