Our acceptance criteria field seem to be in text field multi-line type but is does not support having bullet points or numbering format. Is there a way to configure this?
You need to set field's renderer to Wiki style renderer. You need to go to your Project's settings -> Fields -> Actions (top right corner) -> Edit Fields -> search your field -> Renderers
Just for visibility, here the guides:
Configure renderers | Atlassian Support
Specify field behavior | Atlassian Support
Hope this helps you :)
Fernando
