how to make view only screen the same as in edit screen for a Story recor
christie_ding
September 26, 2025
I created the field Acceptance Criteria and added it in the screen of Story. In the Story record's Edit mode, this field is below Description field (since I moved it down to below description field when config the screen schema) but in the view only screen, this field is above Description field (in the "Details" section". How can I move this AC field down below Description field in the view only screen. Thanks!
Matteo Vecchiato
September 26, 2025
Hi @christie_ding ,
Welcome to Atlassian community.
To set the fields layouts for each work type, after configuring the screens (create, edit, view), you can access the manage field layout section, as described here:
https://support.atlassian.com/jira-software-cloud/docs/configure-field-layout-in-the-work-item/
I hope it clarify
ENTERPRISE
