Hi there,
I recently set up teams to help filter our development work as we have two teams in the dev organization.
After doing this, I now keep seeing this in my dashboard - I do not know how to turn this off
I checked the project our stuff is in and it shows this feature is off. I see nothing about it in the teams view or settings.
Hello @eric caprio
Based on my experience, On-call schedules might appear if certain project features or Opsgenie integrations are enabled.
Check the project settings or Opsgenie configurations to disable this feature if it’s unnecessary.
If you’re unable to locate the option, I suggest reaching out to Atlassian support for detailed help at https://support.atlassian.com/contact/#/.
