how to update assignee on an issue via REST api
ofer hai March 20, 2015
I'm using JIRA REST api 6.3 and trying to update the assignee on a given issue,
I've managed to create issues, so i assume there is nothing wrong with my credentials and positing method.
I've tried both POST and PUT method on "https://<mycompany>.atlassian.net/rest/api/2/issue/<KEY>/editmeta" and "https://<mycompany>.atlassian.net/rest/api/2/issue/<KEY>" .
I've tried using "{ "fields" : { "assignee" :{"name" : "xxx\}  } }" and
{ "update" : { "assignee" : [{"set" : {"name" : "xxx"} } ] } }
I always get the same response ...
{"The remote server returned an error: (405) Method Not Allowed."}
What am I doing wrong here, according to the documentation it should work ...
Ofer s.Hai
rsperafico
March 20, 2015
Hello Ofer,
Thank you for your question.
How can i assign an issue to a sprint?
# USERNAME, i.e.: myuser
# ISSUE-KEY, i.e.: ABC-1
# CUSTOMFIELD-ID, is the Rank custom field ID (i.e.: 10004)
# SPRINT-ID, is the ID of the sprint (i.e.: 1)
# BACKLOG, is false since we are adding the issue to a sprint not ranking the issue in backlog (i.e.: false)
# DOMAIN, i.e.: mycompany
curl -D- -u USERNAME -p -H "Content-Type: application/json" -X PUT -d '{"idOrKeys":["ISSUE-KEY"],"customFieldId":CUSTOMFIELD-ID,"sprintId":SPRINT-ID,"addToBacklog":BACKLOG}' https://DOMAIN.atlassian.net/rest/greenhopper/1.0/sprint/rank
By running the command above, you will be prompted to type in your password. Alternative, you could add the password to the "curl" command as per following (please, notice the password will be visible if you choose this option):
# PASSWORD, i.e.: mypassword
curl -D- -u USERNAME:PASSWORD ...
In JIRA Agile REST API (Please uncheck the 'Show only public APIs)
You could also refer to JIRA REST API for other api calls.
I would kindly ask you to vote on the answer to increase its visibility in case you find this answer resourceful.
Rafael P. Sperafico
Atlassian Support
Faisal Shamim November 18, 2020
Hello ,
I am using https://apitester.com/ to change assignee over to my Jira cloud instance,
Can anyone please guide how to do . I am prettty new to use API to perform such actions.
I tried using : curl -D- -u USERNAME -p -H "Content-Type: application/json" -X PUT -d '{"name":"ASSIGNEE"}' domain/rest/api/2/issue/ISSUE-KEY/assignee . But it didn't work
Faisal
Adity Dokania
May 5, 2016
Do we have a solution to this? I have the exact same issue
rsperafico
March 24, 2015
Hello Ofer,
I would kindly suggest you on, when in JIRA please hit "g" twice on your keyboard (i.e.: g + g). This will open a dialog box in the top-center of your screen.
In the dialog box, please enter:
For "SPRINT-ID", please click on "Agile" located at the top menu and select a board. After that, select "Reports" in the left-menu. In the URL, you should find "view=reporting&chart=sprintRetrospective&sprint=X" where "X" is the SPRINT-ID.
Regarding on "addToBacklog", as mentioned previously, you have to provide a boolean value (true || false). If you are planing to add this issue to the backlog you should use "true", otherwise, "false" to add it to the sprint.
Rafael P. Sperafico
Atlassian Support
ofer hai March 23, 2015
Hi Rafael,
Thank you for your response, I'm a bit confused here:
What custom field should i use and where can i find the sprint id, i only have the sprint number in the current project. why should i call addtobacklog ?nd what value should i put in ?
Is it only 'BACKLOG' text ?
Thank you in advance .
Ofer.
Hi Rafael,
Thank you for your helpful reply.
I wonder how come this solution was not documented at all ? Am i looking at the wrong location:
https://developer.atlassian.com/jiradev/api-reference/jira-rest-apis
If so please refer me to a valid documentation.
Another Q: How can i assign an issue to a sprint ?
Ofer.
rsperafico
March 20, 2015
Hello Ofer,
Could you please run the following command:
# ASSIGNEE, i.e.: otheruser
curl -D- -u USERNAME -p -H "Content-Type: application/json" -X PUT -d '{"name":"ASSIGNEE"}' https://DOMAIN.atlassian.net/rest/api/2/issue/ISSUE-KEY/assignee
If you find this answer useful, I would kindly ask you to accept it so the same will be visible to others who might be facing the same issue you have inquired.
Thank you for your understanding.
Rafael P. Sperafico
Atlassian Support
Register Now
