how to update the past sprint for closed stories
Hi @Ramesh Krishnan What is the rationale behind changing the sprint for closed stories?
In Jira Cloud, once a story (issue) is closed and the sprint is also closed, you cannot directly change the sprint associated with that issue via the UI. Jira locks the sprint field to preserve historical data integrity.
However, here are a few workarounds depending on your permissions and setup:
Workaround 1
Note: This only works if you're moving it to an open sprint.
Workaround 2
I understand these workaround may not be to your satisfaction, but again, why would you change the sprint of a closed story? Correcting the velocity or estimated/committed values may not be beneficial.
