how to use Microsoft power bi with jira
Jen-Qology
10 votes
Anton Storozhuk
September 26, 2019
Hey @Jen-Qology
Our team released Jira plugin, which allows to create Data Sources for Power BI (with a feature to filter projects and/or fields). Makes life easier for a non-techie https://marketplace.atlassian.com/apps/1221150/power-bi-connector-for-jira?hosting=server&tab=overview
SURESH CHINNATHAMBI
April 6, 2020
Hi Anton,
One particular user can't view datasources in Power BI plugin for jira if he is part of powerbi groups and rest of power BI group members can see datasources. Could you please help us on this why it is not working for one user?
Regards
Suresh
Like Anton Storozhuk likes this
Liubov Topchyi
April 6, 2020
Hello @SURESH CHINNATHAMBI ,
Thanks for your question. We started to investigate this case and come back to you soon.
Liubov
Anton Storozhuk
April 7, 2020
Hi @SURESH CHINNATHAMBI
Thanks for contacting us via Support channel. I'll make sure your setup is running smoothly.
Regards
Anton
Liubov Topchyi
April 8, 2020
We've just released the new version of Power BI Connector for Jira - v2.3.6 where compatibility with Internet Explorer was added.
Please update your instance and let us know if your user is able to see connectors in IE now?
Thank you!
Liubov
9 votes
Navarambh Software - Gmail
November 6, 2018
AIO Power BI Connector for Jira app can be used to easily export Jira data into PowerBI and create the dashboards.
It is the #1 selling Power BI connector for Jira on the marketplace and is used by thousands of organizations world wide, including several fortune 500 companies.
It is available for all the three platforms Cloud/Server/Data Center.
If you would like us to provide some samples or have any questions, please feel free to email us at support@aioreports.com or submit a ticket at https://support.aioreports.com
Link to marketplace app page: https://marketplace.atlassian.com/apps/1219072/aio-power-bi-connector-for-jira
Documentation link: https://aioreports.atlassian.net/wiki/spaces/APBCFJ/overview
Support: https://support.aioreports.com
Regards
AIO Support
Asif Mahmud
July 16, 2019
Hi Support team,
I tried but this is not working. Is there other ways to pull the DATA from JIRA to Power BI? I tried to get JIRA content pack in Power BI but the screen freezing after i enter the JIRA link and Basic Credential. I have attached a screenshot below...not sure what I am doing wrong. Appreciate your help.
Thanks in advance
July 16, 2019
The problem that you have reported seems to be originating from Power BI Jira Content Pack.
Please try AIO Power BI Connector for Jira App available on the marketplace here:
It is available for Jira cloud, server and data center versions. In case of any issues please feel free to reach out at support@aioreports.com
Anton Storozhuk
April 7, 2020
Hi @Asif Mahmud
We're specializing in creating apps for exporting Jira data to business intelligence platforms like:
Fast & responsive support is here to help you to install and configure the app.
Also please feel free to apply for a discount https://www.alphaservesp.com/blog/up-to-50-off-all-of-our-add-ons-at-the-atlassian-marketplace/
Best regards,
Anton.
Stuart Terrell
October 13, 2017
Not sure if I can jump on this thread or not (but will try anyway) I can't get the template to work, I'm at the Connect to JIRA step.
I've entered the URL and used Authentication method Windows but get the following error: Failed to update data source credentials
Any ideas what I need to do/check?
Matthew Murphy August 30, 2018
Stuart, was this issue ever resolved? wondering what solutions you found if so? Thanks
Scott Boisvert
Any thoughts on connecting Jira Server with Power BI, this blog indicates its only available for cloud.
September 5, 2019
You can try our add-on:
https://marketplace.atlassian.com/apps/1219072/aio-power-bi-connector-for-jira?hosting=cloud&tab=overview
In case of any issues please feel free to email us at support@aioreports.com
Regards
AIO Support
Anton Storozhuk
April 7, 2020
Hi @Scott Boisvert
Best regards,
Anton.
Cyrille Arnold
January 16, 2019
Hello, I try to find out how to connect Jira cloud within Power BI desktop. So far, i didn't find any .pbix templates. Any ideas?
Tiago Machado
January 28, 2019
Hi @Cyrille Arnold
Try checking this thread
Regards
Brendan Walker
Did you end up getting this to work? I have API connectivity to Excel if that helps. See my comment at https://community.atlassian.com/t5/Jira-questions/Fetch-data-from-JIRA-to-excel/qaq-p/198786
Monica Labrador February 12, 2018
Has anyone had success with getting data related to a specific project in Jira?
Tiago Machado
February 13, 2018
Hi Monica,
Yes - I was able to make Power BI to run a custom search/query on JIRA and parse its results. In our case, we were required to create a Power BI page with indicators about worklog data.
Is it similar to your needs ?
How familiar are you with Power Bi (create/edit a query on advanced query editor) ?
Tiago.
Monica Labrador February 13, 2018
Hi Tiago,
Thank you for your reply. I was able to edit the query using advanced editor to increase the number of rows returned. I am looking to query for only our projects data. The organization I work for has many departments that use Jira and they each have their own Project.
Do you know how one would add a project key parameter?
Thank you!
Tiago Machado
February 13, 2018
Hi @Monica Labrador,
On this post I showed how to make Power BI query JIRA using a JQL search.
What you could do is to change the JQL from "assignee = currentUser()" to something like "projects in (projectA, projectB, ...)"
Hope it helps
Hi @Tiago Machado
Your post is helpful.
I was able to use the code provided and modify it to bring in only my project's data. However, the data is aggregated. How would I build a table with the issues and necessary fields I am interested in?
Like # people like this
Tiago Machado
February 14, 2018
The "data" you retrieve at the end of my script is a list. So, the first thing to do is convert it to a table (List Tools/Transform -> To Table).
Then you will have a "Column1" with some records. Click on the icon with two tiny arrows on the right of the Column1 to expand its values:
You may select all and then delete the columns you don't want later or select just the values you are interested in.
Then you will have something more likely to a useful table. But the important values aren't available yet. Their are still "grouped" under the "issues" column. Repeat the expand process (click on the two arrows icon), expanding the values to new rows.
And you should repeat the expand procedure until all the important data is available in columns for your reports use.
Regards
Deleted user August 4, 2017
I also cannot get the template to work. I am getting the following message.
GetIssues
OLE DB- of ODBC-error: [DataSource.Error] Web.Contents kan de inhoud niet ophalen van 'https://nameprojectof.myorganisation.local/rest/api/2/search?maxResults=500&startAt=0' (404): Not Found.
Is it possible that this template does not work for on-premises instalations?
Maitrey Patel September 6, 2017
It is working for On premises installations as well. Can you check that REST is enabled for your JIRA?
Tiago Machado
December 29, 2017
Hi Tjitse,
I think the JQL parameter is missing...
The REST API will return status 400 when there is a problem with the JQL query and 403 when the user doesn't have permission to search.
It wouldn't surprise me if Power BI/ODBC/OLE would say that any 4xx status is 404.
Nic Brough -Adaptavist-
November 13, 2015
Depends - can it talk to JIRA over REST?  What does it do, and what do you want from it?
Jen-Qology
Its a data analytics software similar to tableau.
November 13, 2015
Well, I knew that really, but my point is more about what you want from it, and how you propose to connect it to JIRA.
Jen-Qology
I wan to be able to pull the data from jira into building more robust dashboard with Jira and also to create reports through Power Bi
November 13, 2015
How do you plan to connect it it? What's the method for "pull"?
Jen-Qology
Thats where I'm stuck, the goal is to pull, but now sure how I can accomplish that
Jen-Qology
Or even if it its possible
November 13, 2015
The best option is to use REST - it doesn't change much, when it does change, the changes are usually "make more stuff available" and it's available off-the-shelf. But does Power BI support that? At a guess, it'll probably demand access to the database, which is a nightmare because you'll need to build and maintain data dictionaries.
Jen-Qology
ugh
November 13, 2015
Yes, that's pretty much what I say about a lot of Microsoft Software.
Jen-Qology
ditto
Jen-Qology
Can I grab the raw data?
November 13, 2015
What do you mean by "raw"? The data in the database?
Jen-Qology
Can I export the data in other words
Jen-Qology
I just found out I can export from Jira to Excel which is compatible with Power BI such a process! Thanks as always for your help Nic
David LEPICIER
January 14, 2016
In the following link, altassian describe how to create SQL database that you can use with PowerBI or JSON link.
https://tech-connect.atlassian.net/wiki/display/UPH/Microsoft+Power+BI+Connector
NavinV
October 21, 2016
Early this month, a JIRA content pack for PowerBI was released:
https://blogs.atlassian.com/2016/10/jira-content-pack-for-microsoft-power-bi/
Scott Brier
December 6, 2016
Just found this thread - I've been able to crack this using a content pack with some minor tweaks on my end. Happy to share some insights if anyone still has the need.
Here's the content pack link that includes the functions needed: https://onedrive.live.com/?authkey=%21AH4_6OHXy6siE74&cid=E7E2C1CD5556023F&id=E7E2C1CD5556023F%21116639&parId=E7E2C1CD5556023F%21116638&action=locate
Using query functions that produce a REST call using search - then using PBI's query editor to break out the result (json) into table fields. No DB required.
Then you can use DAX to do some pretty neat stuff.
Jonathan Chatwin
Scott,
I've loaded up the content pack and it tends to get stuck on 'getissues' after I provide basic authentication. I was only able to get it to load all issues (all 100,000+!!) once yesterday.
Do you have any insight as how to modify to only get issues for certain projects? I'm new to PowerBI:)!
Jonathan Chatwin
Nevermind - was able to figure it out!
Kevin Hess
July 5, 2017
Jonathan Chatwin - how did you modify to only get issues for certain projects?
Dominic Snell
September 18, 2017
Hi
Scott/ Jonathan - did you manage to edit the query to pull back any other fields other than the ones in the content pack? If so, could you share please, I'm stuck and need some other custom fields that are not showing in the list.
Thanks -
Dom
Gareth Veitch
September 12, 2018
@Jonathan Chatwin how did you figure it out? That's where i'm getting stuck too...
Try to give it ```https://jira.csc.com/rest/api/2/search```
and it spits back:
```Refresh
GetIssues
OLE DB or ODBC error: [DataSource.Error] WebContents failed to get contents from 'https://jirea.csc.com/rest/api/2/search/rest/api/2/search?maxResults=500&startAt=0' (404):.```
