how to use greenhopper or aglie through java api
h November 7, 2017
<dependency>
<groupId>com.atlassian.jira.plugin</groupId>
<artifactId>jira-greenhopper-api</artifactId>
<version>6.7.12</version>
</dependency>
i use it in pom.xml
Nic Brough -Adaptavist-
November 8, 2017
Greenhopper is the original name for what became the Agile add-on, which became the Jira Software application with Jira 7.
"How to use it" is basically "write code for it", we can't really tell you more than that.
h November 9, 2017
i just want to through java api create Sprint or Aglie project,the rest api can't do it;
November 9, 2017
Try sprintManager.createSprint()
h November 9, 2017
i try use SprintManager,this method depends on jira-greenhopper-plugin.jar
<dependency>
    <groupId>com.atlassian.jira.plugins</groupId>
   <artifactId>jira-greenhopper-plugin</artifactId>
</dependency>
This is part of my pom.xml code ,I import this package failed;
Gregor Kasmann_Actonic
November 7, 2017
Which API are you going to use grom "greenhopper or aglie"?
h November 8, 2017
i want to created  a sprint through java api
