I want to filter data by update date. something like below:
https://companydomain.atlassian.net/rest/api/3/search?jql=project in ('WCH')&update>='2022-08-01'&maxResults=0
I tried the url, the update filter doesn't work.
Hello @Jean Wang
The keyword in JQL syntax for joining statements is AND.
https://companydomain.atlassian.net/rest/api/3/search?jql=project IN (WCH) AND update >= 2022-08-01&maxResults=50
Ampersands (&) are interpreted in REST API requests as parameter delimiters, so you were passing a parameter 'update' that the REST API couldn't understand, so it just ignored it.
Next, you don't really need the inverted commas in the JQL if the value being searched for doesn't have any spaces in the name, as per my example shown.
Lastly, sending the parameter maxresults=0 would be ignored too. The maxresults parameter is for restricting the total number of results returned, and you can't restrict that to zero.
Thank you so much, David! A great introduction to JQL.
below is the version I used and it works this time. maxResults=0 returns the total numbe of records in the query, in my case, it gives me the total number of issues under the filter condition.
https://companydomain.atlassian.net/rest/api/3/search?jql=project IN (WCH) AND 'updatedDate'>='2022-08-01'&maxResults=0
Try again and omit the entire '&maxResults=0' part of the query. I think you'll find the REST API returns the exact same number of results, up to the default maximum of 50.
For Jira Cloud, the largest value that you can set for maxResults, and the maximum number of items that will be returned for a single request before pagination of the results occurs, is 100. This is a hard set limit, as documented in feature request JRACLOUD-67722
Refer to the Expansion, pagination and expansion section of the REST API documentation to better understand how the total, startAt, maxResults and isLast parameters are used together for parsing paginated results.
