I want to implement such a function. When a user creates a subtask, the subtask is automatically converted to an issue, and then the issue and the parent issue are associated into a link of type blocks
Hi @zhang store
Can you clarify your use case here? You could simply remove the sub-task issue type from the project or add a validator to the create transition that prevents users from creating sub-tasks.
Once the above is in place, you can then instruct them clearly on how to create linked issues.
The above is a process I’ll recommend rather than converting sub-tasks to standard issues.
Regards.
Well, we originally wanted to use subtask to manage user stories and tasks. However, after using subtask, we found that there was a problem in the estimation of development time. Later, we wanted to use linked issue to solve the problem. However, using the linked issue function of ScriptRunner will cause the dialog box not to close after creating an issue, and it will also lead to the situation that it cannot be linked. So I want to automatically convert subtask to issue by listener after creating subtask
Hi @zhang store
The above is weird and I would suggest looking at your logs to confirm why your linked issues behave as they do.
The process of converting sub-task into linked issues doesn’t also guarantee you that all would be fine because you could the run into the same issues you initially had when creating standard linked issues.
Provide a log entry of what happens when you create a linked issue and the error shown on the screen and I’ll try and assist with this.
Regards.
Looking at your requirements:
1. You want to create an issue using a button just like More>Create Sub-task button.
2. The issue is automatically linked to the issue the button is pressed on.
This is exactly the kind of use case for Create Constrained Issue feature of ScriptRunner.
1. Navigate ScriptRunner>Fragments>Create Script Fragments>Constrained create issue dialog:
2. To automatically linked to the issue, create a behaviour. Navigate ScriptRunner>Behaviours>Add Behaviour>Add same mapping as the button> On Initialiser, add the following script:
if (getBehaviourContextId() == "link-create-report") {
// the name of the issue link
final String issueLinkName = "blocks"
def contextIssueKey = ComponentAccessor.getIssueManager().getIssueObject(getContextIssueId()).getKey()
getFieldById("issuelinks-linktype").setFormValue(issueLinkName)
getFieldById("issuelinks-issues").setFormValue([contextIssueKey])
getBehaviourContextId() and getContextIssueId() are documented here.
Note: If you feel like ScriptRunner is not behaving probably, please submit a report through support portal.
import com.onresolve.scriptrunner.runner.util.OSPropertyPersister
import com.atlassian.jira.security.roles.ProjectRoleManager
import com.atlassian.jira.bc.project.component.ProjectComponentManager
import com.atlassian.jira.issue.IssueFieldConstants
import static com.atlassian.jira.issue.IssueFieldConstants.ISSUE_TYPE
def issueManager = ComponentAccessor.getIssueManager()
def projectRoleManager = ComponentAccessor.getComponent(ProjectRoleManager)
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
if ("create-linked-blocking-issue" == getBehaviourContextId() && "" == getFieldById("customfield_10117").getValue()) {
// 设置类型
def allIssueTypes = ComponentAccessor.constantsManager.allIssueTypeObjects
def issueTypeField = getFieldById(ISSUE_TYPE)
def remoteUsersRoles = projectRoleManager.getProjectRoles(user, issueContext.projectObject)*.name
def availableIssueTypes = []
availableIssueTypes.addAll(allIssueTypes.findAll { it.name in ["Bug", "Improvement", "New Feature"] })
issueTypeField.setFieldOptions(availableIssueTypes)
def contextIssue = issueManager.getIssueObject(getContextIssueId())
def sprintField = customFieldManager.getCustomFieldObjectsByName("Sprint")
def sprintName = contextIssue.getCustomFieldValue(sprintField)?.name?.last()?.toString()
// 设置项目
def projectComponentManager = ComponentAccessor.getComponent(ProjectComponentManager)
def projectComponents = projectComponentManager.findAllForProject(contextIssue?.projectObject?.id)
getFieldById("components").setFieldOptions(projectComponents)
getFieldById("project-field").setFormValue(contextIssue?.projectObject?.name)
// 设置类型
if (contextIssue?.issueType?.name?.contains("Improvement")) {
issueTypeField.setFormValue("Improvement")
} else if (contextIssue.issueType.name?.contains("Bug")) {
issueTypeField.setFormValue("Bug")
} else if (contextIssue?.issueType?.name?.contains("Feature")) {
issueTypeField.setFormValue("New Feature")
} else {
// issueTypeField.setReadOnly(true)
getFieldById("issuelinks-linktype").setFormValue("blocks").setReadOnly(true)
getFieldById("issuelinks-issues").setFormValue(contextIssue.key).setReadOnly(true)
def summary = contextIssue?.summary
getFieldById("summary").setFormValue(summary.substring(summary.indexOf("】") + 1, summary.length()))
getFieldById("description").setFormValue(contextIssue.description)
// 设置Owner
getFieldById("customfield_10117").setFormValue(contextIssue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Owner"))?.name)
// 设置QA
getFieldById("customfield_10114").setFormValue(contextIssue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("QA"))?.name)
// 设置Reviewer
getFieldById("customfield_10113").setFormValue(contextIssue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Reviewer"))?.name)
// 设置优先级
getFieldById("priority-field").setFormValue(contextIssue?.priority?.name)
// 不复制组件值,因为创建链接任务一般都是创建属于其它组件的任务
// 设置时间追踪
getFieldById("timetracking_originalestimate").setFormValue("3h")
getFieldById("timetracking_remainingestimate").setFormValue("3h")
getFieldById("customfield_10106").setFormValue("3")
// 设置标签
String[] labels = contextIssue.labels
getFieldById(IssueFieldConstants.LABELS).setFormValue(labels)
// Sprint的值,暂时不能设置值,只能设置成必填
getFieldById("customfield_10101-field").setRequired(true)
// getFieldById("customfield_10101-field").setFormValue(sprintName)
getFieldById("issuelinks-linktype").setHidden(true)
getFieldById("issuelinks-issues").setHidden(true)
This is my code. There is a problem: each project needs to create a constrained create issue dialog, which is very unfriendly
// 设置类型
// 设置项目
// 设置类型
} else {
// 设置Owner
// 设置QA
// 设置Reviewer
// 设置优先级
// 设置时间追踪
// 设置标签
Register now
