when the user move the issue from in progress to resolve the user id should be display in issue display screen, is it possible to with a script field.
hi,
you can do this with "update issue custom field" post function. you can use %%CURRENT_USER%% as the value.
you need to create a user picker custom field and add it to your view screen of that project.
If you put this field on the transition screen, the user will be able to change it, and then the post-function will destroy what they've written. So don't put the field on any transition screens (in fact, it sounds like it should only be put on the issue view sreen)
Help us plant more trees
