i want to get issues progress in dashboard
최보훈_품질경영실_KBN October 20, 2024
i have Epic issue - Child Issue - liked Issues - subtask
i want to get the progress of the subtask is done or not
by using dashboard .
or is there any way to get the issue's progress in each Epic by using dashboard ?
thanks for reading
Danut M _StonikByte_
Hi @최보훈_품질경영실_KBN,
I'm afraid that there is no Jira native gadget that is able to display epic progress by sub-tasks completion.
My advice is to search on Atlassian Marketplace for a plugin that provides such gadget and is able to calculate epic progress by sub-tasks.
If you consider the idea of using a plugin, you should definitely try is our Great Gadgets app. This app offers some gadgets that allow you to track the progress of the epics by sub-tasks.
Pivot Table & Pivot Chart gadget - can display the progress of the epics based on child issues by issue count, sum of story points, percentage completion in form of multi-dimensional tables, heat-map tables, or charts of various types.
Work Breakdown Structure macro/gadget - displays the issues from a filter/JQL by their hierarchy Epic > Story > Sub-Tasks along with their status thus giving you a quick overview of the epics contents and completion (including sub-tasks)
If you have any questions, feel free to contact support@stonikbyte.com at any time.
Danut.
