in a real project management context when using an epic, one wants to have as the "original estimati
Deleted user October 18, 2023
in a real project management context when using an epic, one wants to have as the "original estimation" the sum of the "original estimations" of all the tasks "underlying" the epic. Is it possible that with Jira Datacenter this function, so necessary and so obvious, is not present? Some of you I'm sure have already solved it, can you give me some hints possibly without using runner scripts or other additional plugins?
Perhaps with Automation for Jira?
Chris K
October 18, 2023
Hello @[deleted]
Yes, there is a solution with Jira Automations by using the lookup function. Please check this community thread:
https://community.atlassian.com/t5/Jira-Software-questions/Automation-Fill-the-Estimate-of-Epic-with-the-Sum-of-all-issues/qaq-p/1621946
Hope this helps and will provide the answer for what you are seeking :)
Chris
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
