inherit Labels
Simon Jackson March 25, 2024
Does anyone know how to create an automation rule so that when you add a label to a parent ticket it automatically appears on a subtask please
2 accepted
4 votes
Valerie Knapp
Hi @Simon Jackson , thanks for your question.
I just tested this, which works -
Can you try this out and give us your feedback if this is what you need / were looking for or not?
Hope this helps.
Cheers
Simon Jackson March 26, 2024
will give it a god and keep you posted
Thanks for your help @Valerie Knapp  all working
Like • Valerie Knapp likes this
Valerie Knapp
You're very welcome @Simon Jackson ! Cheers
Marco Brundel
March 25, 2024 edited
Hi @Simon Jackson ,
When you use the trigger "Field value changed" on field 'Labels' and use a branche on sub-tasks, you can copy the value of labels to the sub-tasks.
Regards, Marco
Valerie Knapp
@Marco Brundel great minds!
Like • Marco Brundel likes this
