Dear,
I'm logged to confluence-server page to insert issue through insert jira/filter then select issue then select table in display options then show the table but the table cannot divide to multi columns.
is there a way to make in multi columns?
Khalid Qassadi
The Jira macro you are using can only exist in one cell of a table at a time. It doesn't know that is part of a table.
