As requested by the modal in "my_work_calendar" I'm trying to migrate to the new addon.
I have deactivated and stopped the trial for "my_work_calendar" but I can't install "com.jiraworkcalendar.work-calendar", the error I'm getting is:
An error occurred during installation. Refer to the logs for more information.
I'm running a basic JIRA Cloud setup so there can't be any conflicting plugins and I assume the plugin should work on Cloud. How do I get this running asap?
Hi Randolph,
"my_work_calendar" and "com.jiraworkcalendar.work-calendar" can not live together and you need to completely uninstall "my_work_calendar" before installing "com.jiraworkcalendar.work-calendar". Just deactivation does not work.
Please let me know if any troubles.
Hi Volodymyr,
Thanks! I did not realize there was a third step. (uninstall). It works now.
My fault, I should put it to the warning message.
