integration jenkings with jira
Alejandro Yudis Amaya Bonilla July 14, 2022
Good morning.
I would like your help, I want to run a pipeline from jenkis, when the status of the workflow changes, is that possible.
Example, if the status goes from in progress to implementation, I automatically tell jenkis to run the following pipeline for me
Craig Nodwell
Hi @alejandro yudis amaya Bonilla this is very possible.  Do you have any plugins available to you?  Like scriptrunner?  You could write an automation that could call a webhook.  You could write an automation that calls a script.
Alejandro Yudis Amaya Bonilla July 15, 2022
So should I install a plugin in Jira? but in jenkis I already have the plugin installed.
There is a manual or guide where I can do that, because in Jira I already have everything automated, I just need to tell Jira to run the pipeline in Jenkis.
Register now
