I have jenkins installed on an ec2 aws instance which has a private ip, so jira can't reach Jenkis, but from jenkis it can reach jira.
What should I do so that Jira can recognize Jenkis, therefore, the jenkins tigger does not work for me
@alejandro yudis amaya Bonilla
Hope you configured OAuth configuration as well. If not please follow below 3 steps and then try again accessing the jira instance.
Step 1: Create OAuth Credentials in Jira for Jenkins
Step 2: Install the Jira Cloud Plugin
Step 3: Add the OAuth Credentials in Jenkin
For working jira with jenkins:
Steps to Work with Jenkins Jira Integration:
Step 1: Build Jenkins Jira Snippets
Step 2: Load Build Data to Jenkins Jira Pipeline
Step 3: Load Deployment Data to Jenkins Jira Pipeline
Step 4: Add Environment and Service Details for Jira
Step 5: Fetch Keys using Custom Logic
Step 6: View Development Data in Jira
Hope this will help you.
Else access below link for detailed steps of integration:
https://support.atlassian.com/jira-cloud-administration/docs/integrate-with-jenkins/
