is it possible to block an epic by tasks?
Sascha Kuntz
April 15, 2024
hey,
is there a possibility to block an epic by its tasks. So that you can only change the epic status to done when all tasks are finished?
Ste Wright
April 15, 2024 edited
Hi @Sascha Kuntz
I don't believe this is possible natively; you could try the "Sub-Task Blocking Condition" now that all parent/child relationships use the same field - but it likely still just work for Sub-tasks.
Edit: I tried this, didn't seem to work for me in relation to Epic/children.
You could use Automation as a native workaround - for example...
  • Create a checkbox field at the Epic-level - All Children Closed? - with one option, "Yes"
  • Check the field's box using Automation if all children are closed
  • Use this field in the Workflow, using a "Value Field" condition
Or, you could...
  • Check when the Epic transitions to Done
  • If any child issues remain open
  • Then reverse the transition
  • And let the initiator know all child issues need to be closed first
You could also look for an App on the Marketplace, which could add this type of condition - check out Apps such as...
Let us know your thoughts!
Ste
Sascha Kuntz
April 15, 2024
Hey @Ste Wright ,
thank you for your help. I will try to check remaining child issues when epic transitions to done with an automation, maybe that will fix my problem.
have a nice day
Ste Wright
Hi @Sascha Kuntz
No worries! Let us know how it goes!
If you need any additional instructions to help set this up, we'd be happy to help :)
Ste
Vicente Domínguez _Decadis AG_
April 15, 2024
Hello @Sascha Kuntz and thank you again @Ste Wright for mentioning us!
I am part of the Decadis team and I would like to propose a solution using our app JWT for Jira Cloud.
It is possible to check if any some issues under the epic are in a certain status with the JWT Jira expression validator . Please, visit the use case Block a transition if some issues under an epic are not in a certain status of our documentation if you are open to use our app.
If you need more information about it, please, feel free to reply to us in this thread or to create a request in our Support Portal.
Best regards,
Vicente
Like • Ste Wright likes this
Reshma Begum {Appfire}
Hi @Sascha Kuntz ,
You can achieve this using the JMWE Linked Issues Status validator
This use case is described here in our documentation.
If you have any questions, please raise a support request from our portal
BTW I am from Appfire, a vendor of JMWE.
Reshma
Maciej Dudziak _Forgappify_
April 15, 2024
Hi @Sascha Kuntz
If you are open to using apps and looking for a ready-to-use solution. We've developed the Linked Issues Validator available as part of the Workflow Building Blocks for Jira app.
Blocking an epic transition is quite simple in it:
Additionally, you can filter which child types should be checked or require that at least one child issue exists.
I would appreciate it if you could give it a try.
Cheers
FREE
Help us plant more trees
