Good morning community,
I have a question, I wanted to know if it is possible to combine multiple projects?
because i have to combine 2 projects with a third project, how should i do?
Depends on what you mean by "combine".
The most obvious answer is to simply move all the issues from those two projects into the third.
I was about to suggest the use of Project Configurator, but that should work too!
Run a search for the issues you want to move (project = X is a good start), then use "bulk edit" to move them to the target project.
Jira will ask you questions about data changes if the issues need to change to match the configuration of the target project.
