hello
Today, when we want to send a Jira to a sprint, the unique way to do it is:
* Being on the backlog list > Click right (on the Jira you want to move) > on the pop up proposing to send option (+ other actions as copy issue link, delete, add flag)> then select the sprint you want.
This is not very userfriendly as we are not always on the backlog.
Is there a way to do it faster beeing on the Jira? Thanks for your sugegstions.
Hi Carolina,
Yes, you can edit the "Sprint" field itself, but be careful not to select sprints with similar names that be messy.
I hope that helps.
Melo
hi @[deleted] thanks for your reply
sorry for forgetting to answer ;-)
