×is there a way to close an Epic (or a Story) when all linked issue are closed?
Please suggest
Hi Vashim,
You can use Automation for Jira addon: https://marketplace.atlassian.com/apps/1215460/automation-for-jira?hosting=server&tab=overview
Hi @vashim shekh,
If you have scriptrunner plugin already, then below script will work for you
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.bc.issue.IssueService
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.issue.IssueInputParametersImpl
import com.atlassian.jira.web.bean.PagerFilter
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def issueManager = ComponentAccessor.issueManager
IssueService issueService = ComponentAccessor.getIssueService()
def linkManager = ComponentAccessor.getIssueLinkManager()
def searchService = ComponentAccessor.getComponent(SearchService.class)
def actionId = 41 // change this to the step that you want the issues to be transitioned to
def transitionValidationResult
def transitionResult
def epicLink = ComponentAccessor.customFieldManager.getCustomFieldObjectByName("Epic Link")
def epic = issue.getCustomFieldValue(epicLink) as String
if(epic){
def issueE = issueManager.getIssueObject(epic);
def jqlSearch = "\"Epic Link\" = ${issueE.key}"
def allDone = true
SearchService.ParseResult parseResult = searchService.parseQuery(currentUser, jqlSearch)
if (parseResult.isValid()) {
def searchResult = searchService.search(currentUser, parseResult.getQuery(), PagerFilter.getUnlimitedFilter())
def issues = searchResult.issues.collect {issueManager.getIssueObject(it.id)}
issues.each { i ->
if (i.getResolution().name == 'Unresolved'){
allDone = false
if(issueE.getStatus().name != "Done" && allDone)
transitionValidationResult = issueService.validateTransition(currentUser, issueE.id, actionId,new IssueInputParametersImpl())
if (transitionValidationResult.isValid()) {
transitionResult = issueService.transition(currentUser, transitionValidationResult)
if (transitionResult.isValid())
{ log.warn("Transitioned issue $issue through action $actionId") }
else
{ log.warn("Transition result is not valid") }
}else{
log.warn("The transitionValidation is not valid")
BR,
Leo
Register Now
