i would like to generate chart with Team versus Sprint or Team versus status in dashaboard.
is there a way to report chart in TEAM level?
Hi @Ramesh Krishnan ,
Natively, unfortunately, it's not possible, but with the app I developed - Multi-team Scrum Metrics & Retrospective - you can do this. For this, you will need to use the Custom JQL feature. Here is the example of it:
Also, you can see the summary:
You can:
Best regards,
Alexey
Hi @Ramesh Krishnan,
As explained by @Vishal Biyani, the Team field is not available in the Jira's native gadgets.
If you consider the idea of using a plugin from Atlassian Marketplace, our Great Gadgets app offers a Pivot Table & Pivot Chart gadget that supports the Team field. By using this gadget you can create all kind of multi-field stats in form of tables, heatmap tables or chats of various types.
Danut.
As far as I know, the team field is not available in the gadgets. The work around is to create a custom field and use JIRA automation to populate this field when Team field is updated.
Then use the custom field in the gadgets say two dimensional filter
