issue revoking oauth2 token in forge app
I have an application that connects to google and get the profile details, everything works fine with the authorization and getting the profile.
However I want to add the option to revoke access from my application, and currently i don't see this possible programmatically.
google api to revoke token:
curl -d -X -POST --header "Content-type:application/x-www-form-urlencoded" \
        https://oauth2.googleapis.com/revoke?token={token}
I'm using fetch to call the remote:
const google = api.asUser().withProvider('google', 'google-oauth');
const response = await google.fetch('/revoke', {
method: 'POST',
headers: {
'Content-Type': 'application/x-www-form-urlencoded'}});
in this case the token is actually never sent and I always get bad request error.
since bearerMethod type "
form-encoded" and "uri-query" is depreciated there is no way to call the revoke.
does anyone have a solution?
Dave Rosenlund _Trundl_
June 27, 2024
Hi, @Mazen Chmait_FusionTech Innovations_Marketplace Partner  👋
Did you know there's a special/dedicated Atlassian Community for developers like you?
In other words, you may have better luck with this question in The Atlassian Developer Community.
Best,
-dave
Hi @Dave Rosenlund _Trundl_ ,
Thank you for sharing this, I already posted the same question on the developer community.
Mazen
Like Dave Rosenlund _Trundl_ likes this
