issues getting stuck on transitions
gagan m s February 7, 2018
hello ,
i have added a screen to one of the transitions in the workflow.
however when i try to use it on the issues, it is getting stuck at loading screen.
this is issue happens only when i have added custom screen to transition or else everything works fine.
Fabrizio Galletti
February 7, 2018
First of all check your application log, usually some error should be present there.
When i'd a similar behaviour was generated by a particular custom field not rendering correctly.
Try to add a different transiction screen without any field, meanwhile check if you have some particular condition on your transaction
thanks for the answer Fabrizio.
here is what i got in catalina
07-Feb-2018 00:00:45.915 WARNING [http-bio-443-exec-418] com.sun.jersey.spi.container.servlet.WebComponent.filterFormParameters A servlet request, to the URI https://snjira.services.conduent.com/rest/issueNav/1/issueTable/stable, contains form parameters in the request body but the request body has been consumed by the servlet or a servlet filter accessing the request parameters. Only resource methods using @FormParam will work as expected. Resource methods consuming the request body by other means will not work as expected.
and in Jira software log
06-Feb-2018 09:24:45.939 WARNING [main] org.apache.catalina.startup.SetAllPropertiesRule.begin [SetAllPropertiesRule]{Server/Service/Connector} Setting property 'maxSpareThreads' to '75' did not find a matching property.
i found that my summary and description fields are causing this issue.
how can i go about now?
Nic Brough -Adaptavist-
February 10, 2018
Read the application log.  Catalina.log is the Tomcat server log, you need to have a look at atlassian-jira.log
