There is task management workflow after I create a Task management I try to edit the transition and published,but in issue view screen,it is still the old. I want to know is there any possible to edit the template workflow?
Issue view screen should be edited into screen scheme of a project, but not into workflow.
Vasiliy was trying to get at the separation of screens.
JIRA uses a "screen scheme" to enable you to have different screens for the three main actions - create, view and edit. You can then edit the workflow to change the "transition" screen to something else.
Hi Nic, it's not about Screen Scheme. What I described only JIRA build-in template workflows.
I doubt that it's related to JIRA's own template workflows that they maybe not allowed to edit(very probably), or it maybe related to global transition.
Oh, sorry, I thought it was about locating the different screens.
I'm not actually sure what the question is - what you are pointing at is the transition you need to change, and it looks like you are changing the transition screen fine?
Hi Nic,I know the reason now, the template workflows add jira.i18n.title transition properties so that whatever I modified the transition, it's always the one be set.
I'm glad you've found it, but I don't understand the explanation as it has nothing to do with the question or what we've discussed.
