×Hello folks,
Brief Description:
I am currently running on 9.10.1 and I wish to upgrade to 9.11 due to a recent change that is in this version that'll help improve the business.
Although our 9.10.1 version is a very recent install I'm having some issues with 9.11.
Environment:
Red Hat Enterprise Linux release 8.8 (Ootpa)
Jira 9.10.1 (Datacenter License)
Postgresql-15
Steps to reproduce:
Move Jira install file (Atlassian-jira-software-9.11.0-x64.bin) to VM (placed in data/temp)
Navigate to directory of Jira install file
Enter "chmod a+x atlassian-jira-software-9.11.0-x64.bin" into CLI press Enter
Enter "./Atlassian-jira-software-9.11.0-x64.bin" into CLI press Enter
Expected Result:
Unpacking JRE ...
Starting Installer ...
This will install Jira Software 9.11.0 on your computer.
OK [o, Enter], Cancel [c]
Result Seen:
Unpacking JRE ...
WARNING: A terminally deprecated method in java.lang.System has been called
WARNING: System::setSecurityManager has been called by com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor (file:/data/TEST/atlassian-jira-software-9.11.0-x64.bin.155374.dir/i4jruntime.jar)
WARNING: Please consider reporting this to the maintainers of com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor
WARNING: System::setSecurityManager will be removed in a future release
java.lang.NoSuchFieldException: override
at java.base/java.lang.Class.getDeclaredField(Unknown Source)
at com.install4j.runtime.util.internal.ReflectionUtil.setUnsafeAccessible(ReflectionUtil.java:46)
at com.install4j.runtime.util.internal.ReflectionUtil.setAccessible(ReflectionUtil.java:19)
at com.install4j.runtime.util.ToolTipHelpLabel.initTooltipManager(ToolTipHelpLabel.java:21)
at com.install4j.runtime.util.ToolTipHelpLabel.registerWithToolTipManager(ToolTipHelpLabel.java:61)
at com.install4j.runtime.util.ToolTipHelpLabel.<init>(ToolTipHelpLabel.java:38)
at com.install4j.runtime.beans.formcomponents.UpdateAlertComponent.createCenterComponent(UpdateAlertComponent.java:109)
at com.install4j.runtime.installer.frontend.FormPanel.addFormComponent(FormPanel.java:508)
at com.install4j.runtime.installer.frontend.FormPanel.buildPanel(FormPanel.java:382)
at com.install4j.runtime.installer.frontend.FormPanel.setupComponent(FormPanel.java:310)
at com.install4j.runtime.installer.frontend.FormPanel.init(FormPanel.java:65)
at com.install4j.runtime.installer.frontend.FormPanel.<init>(FormPanel.java:55)
at com.install4j.runtime.installer.frontend.headless.ConsoleScreenExecutor.handleScreen(ConsoleScreenExecutor.java:44)
at com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor.execute(AbstractHeadlessScreenExecutor.java:96)
at com.install4j.runtime.installer.controller.Controller$1.run(Controller.java:155)
at java.desktop/java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue$4.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)
Can this be reproduced: Yes consistently.
This has been identified as a bug:
Can be closed.
Bug report can be found here: https://jira.atlassian.com/browse/JSWSERVER-21948
Register Now
