Subject: Jenkins–Jira Integration Issue
The main purpose of this integration is to visualize the build status in Jira when a Jenkins build is initiated, using the Jira key and Deployment panel. I have created a key and configured the webhook, but I am encountering an error on the Jenkins side.
The issue seems related to Atlassian Cloud: version 2.015 is not supported, so I manually installed version 2.014. However, when I test the connection and try to save, I get the following error:
Error Saving Connection
JSONObject["sites"] is not a JSONArray.
I have tried removing the old configuration and restarted the Jenkins server, but the error persists.
Could you please advise on how to resolve this issue?
Hi @Yugendra
Welcome to the community.
Disclaimer up front: I'm the developer and maintainer of the Jenkins for Jira app.
Going from your message I searched for the Atlassian Cloud version 2.015, but was not able to locate this app/plugin. Can you point me to it?
Knowing what plugin/app you are using will help in finding out what the problem is.
Mark
Hi Mark,
Thanks for the reply first I have installed atlassian cloud 2.0.15. However it didn't work so, I have added 2.0.14 facing the above issue.
Sorry, its 2.0.15
Found it.
I don't see any thing that stands out as to why its not working for you.
Have you tried deleting any existing files related to the plugin?
The error to me sounds like a failure to read the configuration when the plugin starts.
