jira and confluence user count
David Ghoussoub November 18, 2013
I have a JIRA on Demand for 100 users and enabled confluence for 10 users. When I check the application access under user management, i am seeign 7 exceeded under Confluence although I did not grant access to any of my users to Confluence.
David Maye
November 19, 2013
You can look at my.atlassian.com and find out how many users your evaluation for Confluence is for (just to double check). Otherwise, you may have default application access setup to allow Confluence.
HosseinA
November 18, 2013
Hi David,
In order to identify the users, you may run the query below against your Confluence database.
SELECT
o.list_index,
d.active,
d.id as DirectoryID,
d.directory_name,
d.directory_type,
u.id as UserID,
u.user_name
FROM
cwd_user u
JOIN cwd_directory d
ON
u.directory_id = d.id
JOIN cwd_app_dir_mapping o
ON
d.id=o.directory_id
ORDER BY 2 DESC, 1 ASC;
Hope this helps.
Hi Hossein,
Does this apply to the onDemand version of Confluence? How would I run the above SQL statement?
Dave
November 18, 2013
This isn't possible in OnDemand
Let's build A Rovo Agent 🤖
Save your spot
