We have a application tunnel to our onpremise enviroment.
But it keeps giving status error.
We have make a new link but still we get an error.
What can we do more to make the tunnel working again
Hi @Paul Sprang ,
Here are a couple of resources that might help:
Generally, if the tunnel status is in "Error", this usually points to issues with your DC instance. You could check the log files in the on-prem environment. Also, try to regenerate the security key and update it.
If you can dig out what specific error message you're getting, maybe we could troubleshoot it further. 👀
Tobi
thks for the reply. i look into it
