we have a jira instance and we want to let people outside of the company network connect to it.
We created a URL and added a F5 in front of the network. I modified the server.xml use Atlassian guidelines adding these attributes to the Connector node :
proxyName="jira-int.mydomain.com"
proxyPort="443"
scheme="https"
and added the certificate to the java cacert.
Now I can connect from outside the company's network but I cannot connect from the inside and the base URL gadget check fails. Looking into the logs I get this stacktrace :
2018-10-31 10:14:15,657 HealthCheck:thread-5 ERROR ServiceRunner [c.a.j.p.healthcheck.support.BaseUrlHealthCheck] An error occurred when performing the Base URL healthcheck:
org.apache.http.conn.HttpHostConnectException: Connect to jira-int.mydomain.com:443 [jira-int.mydomain.com/192.168.2.45] failed: Connection refused: connect
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:151)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:353)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:380)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:55)
at com.atlassian.jira.plugins.healthcheck.support.BaseUrlHealthCheck.doCheck(BaseUrlHealthCheck.java:53)
at com.atlassian.jira.plugins.healthcheck.support.AbstractSupportHealthCheck.check(AbstractSupportHealthCheck.java:23)
at com.atlassian.support.healthcheck.impl.PluginSuppliedSupportHealthCheck.check(PluginSuppliedSupportHealthCheck.java:51)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:337)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:134)
Does anyone have an idea of what happens ?
Thanks for your replies.
Can you please check the domain resolution internally? and also see if you are able to connect base-url (jira-int.mydomain.com) on 443 successfully. To do that, login to server where jira is hosted and do the below;
telnet jira-int.mydomain.com 443
Check if you are able to connect fine on port 443. If not, then there is port block. You may need to open 443. Typically the above jira-int.mydomain.com should be resolving to your F5 Virtual server.
-Shankar
That was the way... It told me that ports were not available and my whole architecture was somewhat wrong.
Thanks again and have a good day.
Not sure why this is shown as "Solved" !!! https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwikmdS34s_qAhUUu54KHUmBBUAQFjACegQIARAB&url=https%3A%2F%2Fcommunity.atlassian.com%2Ft5%2FJira-Software-questions%2Fjira-base-url-connection-refused%2Fqaq-p%2F928946&usg=AOvVaw3DczHpzkIZPbSdUB6teSp5
