Hi @Arsin Effecta
The descriptor installs okay for me.
Can you please try browsing to your descriptor baseUrl to verify it is correct?
ie.
https://85149a26.ngrok.io/JIRA/atlassian-connect.json
should show your descriptor.
Also, I recommend following the developing locally guide, as the JIRA logs may provide more info and you won't need to list your add-on in Marketplace until it is ready.
Still it is showing as Invalid .json descriptor file
This is the file content
{ "name": "Hello World Plug",
"description": "Atlassian Connect add-on",
"key": "net.ArsinEffecta.jira.Eff",
"baseUrl": "https://85149a26.ngrok.io/JIRA",
"vendor": { "name": "Arsin, Inc.", "url": "http://arsin.com" }, "authentication": { "type": "none" }, "apiVersion": 1, "modules": { "generalPages": [ { "url": "/Helloworld.html", "key": "hello-world", "location": "system.top.navigation.bar", "name": { "value": "Greeting" } } ] } }
You have two semicolons in your Atlassian Connect descriptor. Try using this instead:
{ "name": "Hello World", "description": "Atlassian Connect add-on", "key": "net.ArsinEffecta.jira.EffectaPlug", "baseUrl": "https://arsin-it.atlassian.net", "vendor": { "name": "Arsin, Inc.", "url": "http://arsin.com" }, "authentication": { "type": "none" }, "apiVersion": 1, "modules": { "generalPages": [ { "url": "/Helloworld.html", "key": "hello-world", "location": "system.top.navigation.bar", "name": { "value": "Greeting" } } ] } }
Also, you should use the Atlassian Connect Validator to verify that your descriptor is correct.
Currently I don't have any local instance of JIRA.I just use trial version of JIRA cloud and developed one simple plugin to host it as private add on.
Please refer the file from here.
https://46161658.ngrok.io/App/atlassian-connect.json
This is the file content:
{ "name": "Hello World", "description": "Atlassian Connect add-on", "key": "net.ArsinEffecta.jira.EffectaPlug", "baseUrl": "https://arsin-it.atlassian.net";, "vendor": { "name": "Arsin, Inc.", "url": "http://arsin.com"; }, "authentication": { "type": "none" }, "apiVersion": 1, "modules": { "generalPages": [ { "url": "/Helloworld.html", "key": "hello-world", "location": "system.top.navigation.bar", "name": { "value": "Greeting" } } ] } }
Please try using the validator before installing it in a cloud instance: https://atlassian-connect-validator.herokuapp.com/validate
You'll probably need to post the json file in order for us to help you. Does it work when you install it on a local instance? Is the json file listed as private add-on on the marketplace?
