jira-rest-java-client-core 5.1.6 and JSONException
Virginia Lizana Gil
February 18, 2020
Hi!
I've been using com.atlassian.jira 5.1.6 library for a weeks and it was fine. Today (18/02/2020) it stoped to work. I have a org.codehaus.jettison.json.JSONException: JSONObject["name"] not found.
Any idea please??  Thanks...
POM:
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-rest-java-client-core</artifactId>
<version>5.1.6</version>
</dependency>
<dependency>
<groupId>io.atlassian.fugue</groupId>
<artifactId>fugue</artifactId>
<version>3.0.0</version>
<dependency>
Java
String JQL_JIRA_ACTIVE_SUBPROYECTS = "issuetype = Epic AND project in (SRT) AND status = 'In Progress' ORDER BY cf[12818] DESC, lastViewed DESC";
AsynchronousJiraRestClientFactory factory = new AsynchronousJiraRestClientFactory();
jiraClient = factory.createWithBasicHttpAuthentication(new URI(MY_URI), MY_USR, MY_TOKEN);
SearchResult result = (SearchResult) jiraClient.getSearchClient().searchJql(JQL_JIRA_ACTIVE_SUBPROYECTS).get();
 Error:
Throwable , RestClientException{statusCode=Optional.absent(), errorCollections=[]} :java.util.concurrent.ExecutionException: RestClientException{statusCode=Optional.absent(), errorCollections=[]}
at java.util.concurrent.CompletableFuture.reportGet(CompletableFuture.java:357)
at java.util.concurrent.CompletableFuture.get(CompletableFuture.java:1895)
at io.atlassian.util.concurrent.Promises$OfStage.get(Promises.java:353)
at com.atlassian.jira.rest.client.internal.async.DelegatingPromise.get(DelegatingPromise.java:101)
at TestConnetJira.test(TestConnetJira.java:79)
at TestConnetJira.main(TestConnetJira.java:41)
Caused by: RestClientException{statusCode=Optional.absent(), errorCollections=[]}
at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:191)
at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:185)
Caused by: org.codehaus.jettison.json.JSONException: JSONObject["name"] not found.
at org.codehaus.jettison.json.JSONObject.get(JSONObject.java:360)
at org.codehaus.jettison.json.JSONObject.getString(JSONObject.java:487)
at com.atlassian.jira.rest.client.internal.json.JsonParseUtil.parseBasicUser(JsonParseUtil.java:192)
Virginia Lizana Gil
February 19, 2020
Good Morning.
First, excuse me for my English ... The problem is that jira, for a few days, does not return the "name" field of the user and when parsing the JSON, when not finding the parameter, it returned an exception.
I have solved it in a way that is not the best and I don't like it, but at the moment I couldn't find another one: decompile the class com.atlassian.jira.rest.client.internal.json.JsonParseUtil and in the parseBasicUser method replace:
username = json.getString ("name");
By
String username = "";
if (json.has ("name")) {
I will be attentive to the next attlassian library in case they solve this problem since although it works in this way, you are modifying a foreign class and it is not the best solution.
I hope it helps you. A greeting and thanks for the help.
Shashank Thorat March 3, 2020
<dependency>
<artifactId>jira-rest-java-client-api</artifactId>
<version>5.2.0</version>
</dependency>
<dependency>
<artifactId>jira-rest-java-client-app</artifactId>
</dependency>
The latest dependency solves the issue
Oleg Valeev
February 19, 2020
Looks like this is the cause. Jira Cloud API doesn't return name of user anymore. We also stuck with this error today.
https://developer.atlassian.com/cloud/confluence/rest/?_ga=2.68352215.737964662.1582108886-1288132870.1581605383#api-user-get
NOTE: Personal data that is used to identify users, such as username and userKey, has been removed from the Confluence Cloud REST API
Aleksandr Paren
February 20, 2020
Hi. it seems they hide information about userKey and usrname.
If we look into the getting user info we can not find data about userKey and usrname.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/?utm_source=%2Fcloud%2Fjira%2Fplatform%2Frest%2F&utm_medium=302#api-rest-api-3-user-get
 "key": "",
  "accountId": "5b10a2844c20165700ede21g",
  "name": "",
Spencer Loveridge
March 3, 2020
+1
Assumption is that BasicAuthentication has been deprecated as the response message is the text:
"Basic auth with password is not allowed on this instance"
As this is not in a JSON from you get the
JSONObject["name"]
error as the error text is not in JSON format.
So it would seem that you need to authenticate via API tokens instead. Can't confirm this, but thats my assumption
Diego Daibert February 20, 2020
Same problem here!
Iulian Baranai February 19, 2020 edited
Hi, having the same problem with jira-rest-java-client-api-5.1.0 library.
Observed the issue was raised also here:
https://community.atlassian.com/t5/Jira-questions/REST-API-numerous-calls-now-throwing-an-error/qaq-p/1305234
And the reason behind it is:
https://developer.atlassian.com/cloud/jira/platform/deprecation-notice-user-privacy-api-migration-guide
Not sure if an update for the libraries is available at the moment.
Shashank Thorat February 19, 2020
Stuck with the same thing when I try to do getIssue by passing the ticket number. Any idea how to fix this?
