in a story i see my subtask
i see that i can configure the columns in the subtasks section
when i do it , it's only work for me and the story in question
how can i configure it for all the teams
thanks for your help
Hi @Vince
Do you want to make your column order as the global config for all your colleagues like yours?
I can't help currently because it's weird in my environment of 3 sites that I can't change the order of the columns of subtasks manually as shown in your sreenshot.
Hi @Vince ,
I don't have that customization in 4 of our Cloud instances! But it seems like it works only as a user defaults, not the entire project user group unfortunately.
Actually that missing piece made us add this functionality to the app we develop, called Pivot Report. It allows you adding customizable Issue Tree and Issue Progress widgets right to the Issue View:
Setup of both could be done on a project level per issue type. Settings include options of extending/gathering parent/child issues to get the tree/roll up values. Thus Project admin(s) can setup both gadgets, so any user will see the same set of columns and values.
In the future we are planning (actually, we've been requested multiple times) to add Pivot widget as well.
I'm sorry if that is something you haven't asked for. It's just the concept of Issue View level reporting is not common. I'm trying to tell the world it's possible to be achieved.
