×Can we create a layout each work item type or issue type in Jira.?
if yes, what is the procedure to create a layout in jira?
Soubhagya
Hi Soubhagya - Welcome to the Atlassian Community!
Issue layouts are based on a combination of Screen and Issue Type. You can modify using the Configure button at the bottom right of an issue screen. Then you can copy the layout to other projects for that same screen and issue type.
Thanks for your answer.
is it possible to create a new layout in Jira?
I can see view or edit the layout of your project’s work types.
Next to your project's name in the sidebar, select More actions (•••), then Project settings.
Select Work items, then Layout.
Find the work type(s) whose layout you want to view and select Edit work item layout. You’ll see the work item
