×Hi, I use the Workflow Essentials plugin to do a Post Function on the workflow transition "Create".
I want to copy the value of a custom field from the parent issue to the currently created issue: form issue to subtask.
This results in a error:
Error creating issue: Could not copy the value from field Team from parent to sub-task. The technical error message is: Java type com.atlassian.jira.issue.customfields.option.LazyLoadedOption not currently supported
Please help.
Hi Leon,
please try the latest version (https://marketplace.atlassian.com/plugins/de.codecentric.jira.wes/versions) of the plugin.
Joerg
Hi Leon,
thanks for the feedback. We are investigating and come back soon with an answer.
Joerg
