Hello Everyone.
I am new to jira plugin development. I am trying to create a hello world plugin with a read write access. I was using PHP for the back end just for a quick play around. My installed hock is fired by installation process, however, my POST variable (the payload) is empty. I suppose, it should contain some information and not sure why I am not receiving it.
Here is the the json file
"name": "JIRA Connect 2",
"description": "Test from",
"key": "aut2.jiraplugin.mydomain.ca",
"baseUrl": "https://ab5c7641.ngrok.io/creatros-jira",
"scope":[
"read","write"
"vendor": {
"name": "our company Inc.",
"url": "http://mydomain.ca"
"authentication": {
"type": "JWT"
"lifecycle":{
"installed":"/jwtSave.php"
"apiVersion": 1,
"modules": {
"jiraProjectPages": [
"key": "query-test",
"name": {
"value": "Search Users"
"url": "/query.html?projectKey=${project.key}",
"iconUrl": "/search-user.png",
"weight": 0
And the jwtSave.php as following
<?php
ob_start();
var_dump($_REQUEST);
print_r($_POST);
print_r($_GET);
print_r($_SERVER);
$result = ob_get_clean();
file_put_contents(date("U").'-.txt', $result );
and for the print_r($_POST) statement i am getting
Array() <- an empty array. Nothing sent.
Any help will be greatly appriciated.
I found a solution at https://stackoverflow.com/questions/18866571/receive-json-post-with-php
Thanks everyone for your attention.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
