list of unused custom fields via scriptrunner
NSEU DevOps April 24, 2023
I am running a Datacenter instance (8.20.14) and I need to perform an audit on all unused custom fields (and we have a large amount).
I have used the Jira tool "Custom Fields Optimizer" to a list of all custom fields within a project but unfortunately, this tool does not allow an export of all custom fields to a CSV file so I can manipulate it.
Is there a way via either Scriptrunner or the API I can get this list on Datacenter?
Vikrant Yadav
Hi @NSEU DevOps  Check this doc for managing custom fields :- https://confluence.atlassian.com/enterprise/managing-custom-fields-in-jira-effectively-945523781.html
OR you can run the following script in Script Console to get a list of empty custom fields :-
import groovy.sql.Sql
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def delegator = (DelegatorInterface) ComponentAccessor.getComponent(DelegatorInterface)
String helperName = delegator.getGroupHelperName("default")
def sqlStmt = """
select count(*), customfield.id, customfield.cfname, customfield.description
from customfield left join customfieldvalue on customfield.id = customfieldvalue.customfield
where customfieldvalue.stringvalue is null
and customfieldvalue.numbervalue is null
and customfieldvalue.textvalue is null
and customfieldvalue.datevalue is null
group by customfield.id, customfield.cfname, customfield.description;;
Connection conn = ConnectionFactory.getConnection(helperName)
Sql sql = new Sql(conn)
String result = """
<table>
  <tr>
    <th>Customfield Name</th>
    <th>Customfield Id</th>
  </tr>
sql.eachRow(sqlStmt){ it ->
    result += """
        <tr>
          <td>${it.getAt("cfname")}</td>
          <td>${it.getAt("id")}</td>
        </tr>
return result+"</table>"
sql.close()
NSEU DevOps April 25, 2023
Thank you!
Like Vikrant Yadav likes this
Vikrant Yadav
You're Welcome :)
Register here ⬇️
