make each check box mandatory in multi checkbox field jira
NehaNagori June 12, 2017
I have a multi checkbox that i am using in workflow transitions.
currently, on clicking on one check box is sufficient for transitioning a issue. But I want While transitioning a issue, All check boxes to be clicked(as a mandatory field).
Aashutosh Kumar
Too Late Answer, useful for newcomers.
All CheckBox Options can be marked Required, if using Extension for Jira Service Management .
Add CheckBox Field in Customer Form Extensions, and set validator = at least x values required: "Number of Checkbox options"
Project Settings -> Customer Form Extension -> Request Type -> Check Box Field -> Validator -> atleast x values required -> "Number of Checkbox options"
Nic Brough -Adaptavist-
June 12, 2017
If they all have to be mandatory, technically you don't need the field.  You can assume that the user has ticked everything because they're using the transition.
If you do insist on doing this, then you will need to find or write some code for it.  This could get quite "interesting".  Technically, you could just check "number of selected options = x", but what happens if the list changes?  You suddenly have a load of issues that don't match, although they did when they were transitioned.
NehaNagori June 20, 2017
Can we implement this through scripts?
June 20, 2017
Examples of validators can be found under https://scriptrunner.adaptavist.com/4.3.1/jira/recipes/workflow.html (I went higher, because you might prefer a condition instead - a validator will halt a user part way through a transition, whereas a condition will stop them using the transition at all)
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
