We are using Jira server.
Teams are working SCRUM.
We use Jira Plans (formally portfolio) to manage the progress - such as PI progress that includes all Epics per PI.
we would like to manage additional things and need a solution for those two items:
1. Option to set the epic summary on the epic progress bar.
Today, you alwas neeed to scroll to the left side in order to see the issue name / summary.
2. option to manage milestones in Jira plans. My current solution is using a new issuetype and assign same start / end date, so it will appear as milestone without a duration.
Any other better solutions?
Yaron
For #1, there is no way out of the box to accomplish that. If you are open to using a 3rd party plugin, something like BigGantt can do both things you are looking for.
For #2, we also have decided to use a custom issue type for Milestones and this has worked fine for our needs.
