Hi Team :)
I hope all is well. I seem to lost access to my confluence :( is there anything I can do to get it back?
Have a great week ahead!
Kindest Regards
Magdalena
Hello @Magda M
What happens when you try to access the Confluence Cloud instance? Are you getting some sort of error message?
Are the Jira and Confluence instances ones that you set up, in an Atlassian Organization that you created?
Are other people administrators of these instances and/or the Organization in which they exist?
Thank you! The issue was solved - confluence was deactivated
